!! Polaris NON support of Older Product's !!
Anybody had luck getting BALL JOINTS for prior 1989 Trailboss 250 4X4 (s).
I have two a 1987 & 1988 both nice --------- except for Ball Joints.
Any help would be appreciated.
The ball joints are a type that looks similiar to a TIE ROD END ------ not your ordinary Ball Joint.
Maybe this was a flawed design and Polaris is just pushing it aside.
This could help me make a decision on what brand not to BUY !!!!
John in MN.[img]i/expressions/face-icon-small-disgusted.gif[/img]
<div class="FTQUOTE"><begin quote>Originally posted by: John in MN.
John in MN.[img][/img]</end quote></div>
Try 15/16/17/18 is this what you need? Steering assembly. If so you didn't look very hard.
http://houseofmotorcycles.bike...4-w898127-1989/o/m5635
No Rick Mine are 1987 & 1988 - <a target=_blank class=ftalternatingbarlinklarge href="http://houseofmotorcyc...ike.....988/o/m5634
">"><a target=_blank class=ftalternatingbarlinklarge href="http://houseofmotorcycles.bike...27-1988/o/m5634
"><br "><a target=_blank class=ftalternatingbarlinklarge href="http://houseofmotorcycles.bikebandit.com/polaris-atv-trail-boss-4x4-w888127-1988/o/m5634
<br ">http://.....ike...988/o/m5634
</a>
</a>
</a>
---- with part # 62 under steering.
The 1989 year is when they changed the design to a BALL JOINT similiar to what is used on cars/trucks --------- the 1987 & 1988 were more like a " TIE ROD END " .
I was thinking maybe of machining some type of adapter to use the -- 1989 and on type Ball Joint ----- but thats not a very simple project --- because not only devising away to mount BALL JOINT to the bottom of the front strut assemblies --- you also have to change the monting to the front lower A arms !!!!!
So thats why I've yell'd "HELP"
John
</a>
</a>
</a>
John
check http://www.goallballs.com/home.asp or with EPI
Ball Joint Kit - Lower
ALLBALLS PART # 42-1030
http://www.goallballs.com/dealer_tools_results.asp
just replaced mine in 2002 sp700.
Hi jimmypsp700 , That is the BALLJOINT for the new style type.
The 1987 & 1988 Trailboss 250 4X4's I have require a BALLJOINT that looks like a TIE - ROD END !
Thanks for the info - I will probably ask them if they know anyone making them .
John
John
Can't you use one of these with a bolt through it?
http://cgi.ebay.com/ebaymotors...QrdZ1QQsspagenameZWDVW
Are you sure you dont have a 86-87?I have a set of struts off of a 1988 Trailboss 2x4 and they are like the newer ones.The 86-87s were dif.
Ah Ha Squirrelmaster ,
I was wondering about something like that --- one of my son's had mentioned something about hime joints or something like that ------ Thanks for sending that link.
That looks like a good possible solution.
John in MN.
John in MN.
