Fuel valve leak on trail blazer
Fuel Valve is leaking on the on-off position but not on reserve. I put new clamp on hose but didnt fix the problem. It's not the gasket between fuel valve and tank. I thought I saw a post on here about fixing the fuel valve without getting a new one. Can anyone help? Thanks again.
I dissasembled the fuel valve and it was a non repairable part due to the brass fitting being pressed in. I found a broken O ring after dissasembly. Buying a new one thanks anyhow.
