Bayou 3004x4 or Prarie 300 4x4?
Old Jan 8, 2001 | 09:23 PM
Muddog1's Avatar
Is the bayou a better machine with shifting and good towing capacity or is the prarie a better machine because of its sportiness and auto transmission? Or could you recommend a better 300 class atv?
Old Jan 9, 2001 | 12:23 AM
Tree Farmer's Avatar
Your own preference should drive your choice.
The Bayou has semi-independent swing-axle rear suspension, a design more nimble over uneven terrain (as in, rocky) than the swing-arm Prairie.
The Prairie has a cushier ride, although Y2K and later Bayous are reasonably civilized.
Do you like to shift for yourself or prefer an "automatic" transmission? That's the big question.
Either Kawasaki is o.k.; however, all ATV manufacturers produce excellent machines in the 300cc displacement class (but not all have dual-range transmissions, or, as in the Bayou's case, semi-independent rear suspensions).
Tree Farmer
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
