1999 Polaris Scrambler Transmission
Old Nov 30, 2007 | 12:29 AM
1999 Scrambler 's Avatar
Default 1999 Polaris Scrambler Transmission
I have a 1999 Polaris Scrambler 500 4x4 chaindrive that i want to put a R-N-L-H transmission out of something to put in it so i can run bigger tires and crawl over stuff. My Part number on my original transmission is 1341261 , that is the transmission i took out of it . Does anyone know what i can get a transmission out of to satisfy my needs.
Old Nov 30, 2007 | 04:03 PM
big_kid's Avatar
im having same questions about these transmissions but not really getting any info. my tranny on my xpress has H-L-N-R but its two wheel drive and dont know if it would work in a 4 wheel drive aplication. can you get any pics of how the chain set up down by the right foot pad. also if you can get a measurements of how long the output shaft is (coming out of the transmission, where the small sprocket is) i will get a measurement off mine and see if they are the same length....
Old Nov 30, 2007 | 08:35 PM
does it have a shaft coming out of the front right corner of the transmission
Old Nov 30, 2007 | 09:14 PM
big_kid's Avatar
no shaft. i thought you said yours was chain drive....mine is a 97
Old Nov 30, 2007 | 09:16 PM
no that shaft would be for the concentric drive 4x4
Old Nov 30, 2007 | 09:55 PM
big_kid's Avatar
oh, not sure what tranny you would be needing then. what year did they go to the concentric drive. mine has the loose chain until you "sit on it" then it tightens up...
Old Nov 30, 2007 | 10:10 PM
goodblasson's Avatar
I would bet the tranny out of a 1995-1996 Magnum 425 would work. After looking at my buddys 96 scambler 4x4 and my 96 magnum, they look identical. Might want to research that avenue...
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
