Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
do i need to split the engine to change the crank seals?
Old Dec 1, 2007 | 06:46 PM
wizard1212's Avatar
Default do i need to split the engine to change the crank seals?
My left side crank seal is leaking into the crank housing would that cause the motor not to run with the air and oil leaking out of the seal? Should i just change both side seals while im at it and will that leak ruin the cylinder head, i just put a new pistion and rings in the thing but the leaking and smoking of the oil has me concerned
Old Dec 2, 2007 | 08:36 PM
270quadsportguy's Avatar
should be able to change those seals without spliting case depends what u are working on. I have seen where piston blowing apart has also put holes in the lower cases
Old Dec 3, 2007 | 01:38 AM
wizard1212's Avatar
it is a dinli 90cc t rex i just donot want to mess anything up trying to get those seals out
Old Dec 5, 2007 | 12:23 AM
Rudedog's Avatar
You should be able to drill a hole into the face or flat surface of the crank seal. Then put a screw in it and using pliers or vice grips you should be able to pull out the old seal.
Rude Dog
hugemoth
Jul 20, 2020 03:28 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
bikedad3
Jul 2, 2015 02:15 AM
scaldwellk
Jun 19, 2015 05:08 PM
Dabears1983
Jun 16, 2015 12:17 PM
