prop shaf u-joints
Old Dec 2, 2007 | 08:06 PM
sportsman rocks 's Avatar
Default prop shaf u-joints
I need to replace my prop shaft u-joint, I know how to replace them, but wondering where a good place to by them other than polaris. polaris wants over $30 with no grease fitting. has any one hard of Erlandson Performance also as, EPI they want $16.07 online for there's, are they any good? thanks for any help deciding
Old Dec 2, 2007 | 08:51 PM
03scrambler500's Avatar
go to your local Napa store you can get the same quality U joint with a greese fitting for around $8 just take yours with and they should measure it for you but i think the part number is 338 not 100% sure though
Old Dec 2, 2007 | 09:27 PM
Thanks 03srambler500, would you know if the clips on the napa joint are on the in side like the original? when I'm ready ill take mine apart and see if they can mach it up.
Old Dec 2, 2007 | 09:34 PM
yes, every part of the Napa u joint is IDENTICAL to the older greasable polaris style. Even down to the number of needle bearnings in it.
Old Dec 2, 2007 | 09:44 PM
Ok thanks a lot, hopefully my small town Napa shop can mach these up will save me a few $$, more for gas.
Old Dec 4, 2007 | 09:25 PM
hey 03scrambler500, got my new Napa u-joints installed. 338 was the right parts number amazing! That saved me some time and money. Thanks again for the help, Sean
V8s10
Jan 7, 2003 07:56 AM
CraneMan
Dec 12, 2002 07:05 PM
polcat2
Mar 7, 2001 04:56 PM
