'00 trailblazer tranny
Old Dec 3, 2007 | 12:24 AM
eggenz7's Avatar
Default '00 trailblazer tranny
i was out riding today and the tranny was shifting just fine. was going over some wash out places and got stopped by the guy infront of me. well that caused my machine to get stuck. went to go forward and it didnt want to go. tried to put it in reverse and it didnt was to shift. so i pulled the bike backwards then tried to shift...went into reverse just fine.. and i guess it decided it likes reverse because it wont shift into forward anymore. will shift into neutral.. kinda tricky but it will go. any ideas as to what went wrong? i took the adjustment rod from the shifter to the bellcrank loose..still couldnt get it to shift so im thinking something internally went wrong.
any ideas?
Old Dec 3, 2007 | 08:01 AM
ftwflh's Avatar
You have to pull it out anyway take it aprt and see what is wrong.It may be cheaper to fix than replace
Old Dec 3, 2007 | 08:28 PM
tbsleeper's Avatar
sounds like the belt was just slipping at first...but it nto goin back into drive is weird. Something is probably bound up in ur tranny
Old Dec 3, 2007 | 10:35 PM
eggenz7's Avatar
the chain has stretched so much that by the time it gets around to the bottom of the gear it wouldnt even mesh up with the big gear. it finally just came off the gears. dont see any wear on either of the gears so im just gonna replace the chain
Old Dec 3, 2007 | 10:51 PM
jjdirtparts's Avatar
WOW YOU RIPPED THE TRANNY APART IN ONE DAY THAT IS MOTIVATION FOR ME TO DO THE SAME, GOOD LUCK
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
Logan Collins
Sep 5, 2015 08:03 PM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
