valve adjustment?
Old Dec 3, 2007 | 12:22 PM
sooner1's Avatar
Default valve adjustment?
i have a 2005 rancher,its runs fine,but has a chattering coming from the cylinder area.i've heard that it might need a valve adjustment.im handy with cars but havent worked on ATVs much.does anyone have any ideas where i might get started
Old Dec 3, 2007 | 12:57 PM
hondabuster's Avatar
If you buy a service manual, it will describe what needs to be done. Here is an online article on valve adjustment, which should give you a good idea if you want to do it or not. Should be a piece of cake. It usually takes longer to remove the plastic, than it doea to do the check and adjustment.
http://www.motorcyclecruiser.c..._adjustment/index.html
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
