red hot exhaust
Old Dec 7, 2007 | 06:11 PM
Matt1980's Avatar
Default red hot exhaust
my brothers 2007 honda 400ex wouldnt start and we put the battery on the charger and when we did get it started the exhaust turned as red as an apple and we shut it off. Whats wrong, is a valve stuck or something
Old Dec 7, 2007 | 11:02 PM
randallp504's Avatar
sounds like somethings wrong
Old Dec 8, 2007 | 02:33 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Wouldn't start because of a dead battery, or some other reason????
Cold air is more dense, so it might be slightly lean which can make it hot. Don't let it just sit around idling...ride it or shut it off.
Old Dec 8, 2007 | 03:38 AM
hondabuster's Avatar
How long was it idleing? Usually a red hot head pipe is a sure sign of lean, or idleing way too long.
Is the motor totally stock....lid is installed on the air box?
Old Dec 8, 2007 | 05:26 PM
Gimpster's Avatar
The 400 has a single wall pipe. If you hold the throttle open with no load for a spell, it will turn red. If it is doing it idling, I would look into the pilot jet being restricted making it lean and start hard
----- Gregg -----
Old Dec 14, 2007 | 11:36 PM
jimmies440's Avatar
you could check your valves make sure you mave proper valve adj. it should be .006 on the exaust side and .005 on the intake the book calls for .005 and .004 but the .006 and .005 seem to work a little better
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
