ANYBODY ELSE HAVE A LOCKED UP STARTER ON THEIR TRX500FE?
Old Dec 12, 2007 | 03:25 PM
NISMO's Avatar
Default ANYBODY ELSE HAVE A LOCKED UP STARTER ON THEIR TRX500FE?
I WENT TO START MY FOREMAN THE OTHER DAY AND THE STARTER WOULDN'T TURN OVER. BATTERY WAS GOOD, I COULD HEAR THE RELAY CLICKING BUT NO STARTER? I FELT THE STARTER, IT WAS GETTING WARM. I PULLED THE STATER OFF AND WHEN I LOOKED AT THE BENDIX GEAR IT HAD ALOT OF RUST. TOOK THE CAP OFF AND DISASSEMBLED THE STARTER AND FOUND THE NEEDLE BEARING RUSTED SOLID, IS THIS HAPPENING ALOT? REPLACED THE CAP AND IT WORKS FINE NOW.
Old Dec 12, 2007 | 03:41 PM
TLC's Avatar
TLC
Not common, when I take a starter apart I used liquid gasket when I put them back together for back up water proofing of the o rings and connections.
Old Dec 12, 2007 | 06:11 PM
NISMO's Avatar
The starter motor itself was ok, the needle bearing in the cover the slides into the flywheel was rusted solid. How would you seal that opening the starter slides into? There is an o-ring around the cap but how well can it really seal?
Old Dec 13, 2007 | 08:51 PM
angler's Avatar
My Rubicon did the same thing yours did, hearing the relay click but would not turn over. To get it to start I just would hit the starter until I just replaced the starter. I never did inspect it to see what was wrong but it probably did the same thing yours did.
When I took the starter off, there was some kind of white stuff around the gear that is sticking out. I imagine it had to do with keeping water out. I just took what I could get off of it and put it on the new starter.
akguy31
Aug 31, 2019 04:34 AM
flyin-lowe
Dec 1, 2017 03:18 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
