D1,D2 ????? and also valve setting 07 rubicon
Old Dec 17, 2007 | 12:37 PM
MACHZMISSLE's Avatar
Default D1,D2 ????? and also valve setting 07 rubicon
I guess I am kind of confused on this. on a 2007 Rubicon, which is better to use while just cruising around and trail riding or normal use?
Only reason I ask is that I have heard on older models pre 05 that it was backwards.
Any help would be great, also when adjusting the valves what are the spec settings I should be using?? I know how to do it I just don't know what they should be set to.
Old Dec 17, 2007 | 12:55 PM
MikeM's Avatar
whatever you think fits your shifting desires. I found that D2 works well when you want to putt around and keep the revs low, but it was not ready for things that require full power, like a long hill climb. D1 was better if you were riding aggressively.
I preferred ESP. I did not hear they changed D1 to torque peak shift and D2 to hp peak shift.
Old Dec 17, 2007 | 07:11 PM
JeffinTD's Avatar
.006 intake and .009 exhaust.
Old Dec 18, 2007 | 11:08 PM
Gimpster's Avatar
I like setting them a little tight on the feeler gauge.
Honda conciders a cold engine to be like 90 to 95 degrees when valves are set
----- Gimpster -----
slowgsxr97
Mar 18, 2022 03:40 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
