03 Sporty 600 Twin Backfire in Reverse only!?!?!
Old Dec 17, 2007 | 01:53 PM
Schneider600's Avatar
Default 03 Sporty 600 Twin Backfire in Reverse only!?!?!
The other night I was plowing the driveway and I noticed a few times that when I was Backing up after pushing a pile, my machine would backfire. IT only does it in reverse. Anyone ever hear / experience this?
Old Dec 17, 2007 | 01:58 PM
UTU's Avatar
UTU
we are pushing the reverse override button (yellow)in when backing up (:>
Old Dec 17, 2007 | 02:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
im assuming you had the override pushed in since you was plowing. is it the same kinf of backfirng/missing that you get when you dont push the override and the limiter kicks in. just wondering if the override is starting to mess up. the only other thing it can be its running to lean. just a thought.
Old Dec 17, 2007 | 02:51 PM
supergolfer's Avatar
If you release the override button prior to the engine speed coming all the way back down to idle the engine will backfire. The system while the button is pushed is operating normally dumping the regular amount of fuel into the combustion chamber, when the button is released the ignition system "retards" and causes abnormal spark hence limiting speed in reverse and causing intermittent backfires.
It will not cause a problem.
Superintendent
Old Dec 17, 2007 | 02:58 PM
chevyman142000's Avatar
My 01 500HO does this as well. I think it is just because I let go of the override button too soon.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Sw00p
Sep 24, 2015 02:50 PM
