low end bog
Old Dec 19, 2007 | 09:09 PM
onebigzj's Avatar
Default low end bog
I was riding yesterday and realized there is a bog. it doesent have a snap when you hit the throttle. its cold here so it is running lean( from the cold air) I think it should have some snap. could the reeds need to be replaced? they are org. I cant lean it out any more to rid the bog( needle is at top) any other ideas?
Old Dec 20, 2007 | 12:24 PM
LT80's Avatar
LT80 Expert
Default low end bog
If the plug is still dark, jet down a size.
Is this the motor w/the 97 main jet?
Old Dec 20, 2007 | 03:15 PM
onebigzj's Avatar
Default low end bog
i still have to check. 98 main jet. I thought mains were 92?
will check and let you know
