Scrambler 400 4x4 - Cold weather rejetting?
Old Jan 10, 2001 | 07:54 PM
steelheader's Avatar
I have a 2000 model. Dealer says to re-jet (step up one size) for NE Ohio winter weather. It cold starts great and runs excellent after a few minutes of warm-up now. Dealer says posibility of siezure with constant higher rews such as some of the backroad riding we do in cold weather. I've seen some discussion threads lately on cold weather re-jetting on some of the other manufacturer forums but nothing on the Scrambler 2 strokers. Want to thank everyone for your input on this matter as well as all the other info./opinions you share here. This is my first quad and I'm sure I have learn more here in a few months than I would from years of reading magazines.
Old Jan 11, 2001 | 12:47 AM
NEIL's Avatar
it wouldnt hurt to up you jet 1 size but if your jetting is stock you should be ok because the factory usally puts fairly rich jets in to begin with. if you not shure theres a good test you can do: blast down the trail at full throttle an yank on the choke, if your quad boggs and smokes its ok
if it takes off and runs better when you pull the choke you need to jet up.
1990 trail boss 350L 4x4
far from stock
Old Jan 11, 2001 | 01:03 AM
GJ's Avatar
GJ
Steelheader, I have the same quad as you. and live in ohio also. I found i had to reget when riding below 40 deg. It ran a bit wierd and the plug color went from black to white/brown. I regetted to the books spec on the main jet from a 230 to a 250, and it is much better, but is just brown now. I also went in a 1/4 or 1/2 turn on my air screw and that help a bit also. it would be worth your time to look at the plug and see how yours is. if its white dont ride till you get the new jets. I thought going up to a 250 would be to big of a jump so I bought a 240 also, but the 250 is just good enough. I would have liked to see some more black color to it though. I like to play it safe in the jetting area. good luck. gj
Old Jan 11, 2001 | 02:41 AM
Dazed's Avatar
I run the same jetting you do a 250 main but i also raised my needel height buy 2 notches i am one from the top now it is a little rich but hell plugs are cheep moters are not.
Old Jan 11, 2001 | 09:36 PM
bigdevil's Avatar
i was wondering...how about on a piped 400?? i have a 400 with the rcr stage 1 kit, i belive there is a 270 in there.
would i have to rejet also? i live in n.e. pa, which is about the same weather as ohio.
bigdevil '99 scrambler 400 w/rcr stage 1
Old Jan 12, 2001 | 09:59 AM
KevinDevitt's Avatar
I have a 270 in mine for winter riding. I believe that is is still a little rich. I would rather be a little conservative than have to rebuild an engine. In the summer I will take it down to a 260 amybe even a 250. With the 270 I have rode in temps down to 0 with no problems (yet).
I have simular mods to the RCR stage 1.
KD
ultangler
Nov 30, 2024 01:35 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
