HELP!!!!!ASAP
Old Jan 10, 2001 | 08:05 PM
400exalltheway's Avatar
hey, i've been building a 250r since september and just got it ready to turn over tonite. i tried kicking it for about 5min but nothing. would a little starter fluid help? i just can't get the thing to turn over?, checked all my wires and everything but nothing yet, i really wanna get it to run asap. thanks for any help
Old Jan 10, 2001 | 09:10 PM
trapperb1's Avatar
Don't use the starter fluid!!!
Make sure all electrical is correct.
Make sure the gas is on and flowing.
Make sure you have a good new plug in it gapped correctly.
Make sure you have compression (take the plug out and put your thumb over the hole and have someone push the kick start and see if you can keep your thumb over the hole).
Try using the choke on the carb.
Old Jan 10, 2001 | 09:15 PM
tried all that, double check and check over and over the wiring, gas is on(got clear fuel filter), and all that other stuff!!
Old Jan 10, 2001 | 09:17 PM
love250x's Avatar
A little starter fluid might work but don't use too much.A awsome trick to get my 250x(also kick) to start is to take the CDI box off and spray a squirt of WD-40 in it and then try it.If all else fails then get a new plug and ajust the gap to a 250R.Usually a little bit wider.Good luck!
Old Jan 11, 2001 | 03:19 AM
SpeedDemn440's Avatar
check your spark plug to see if its fouled. Hold it next to something metal and give it a kick to see if its even getting any current to it(be careful) next check your compression, and maybe even use a fresh mixed gas that is even a little lean(50:1) I strongly recomend you don't use starting fluid because it doesnt magicaly make your bike start well time and time again unless you are nukeing your carb everytime you wanna ride. Make sure your bike is properly grounded(ground wire) too. i dunno what else to say unless i really brainstorm for a while; brains already starting to hurt so good luk
Old Jan 11, 2001 | 07:46 AM
yeah, i got a new plug freshly mixed gas, compression is good, only thing i can think of is wiring. i did ground the frame wire, i don't have my kill switch hooked up yet and i don't have a handle bar switch could that be the problem? it tries to turn over but just won't. thnks for all the help so far!!!
Old Jan 11, 2001 | 09:52 AM
Boss70's Avatar
As said before, check to make sure you have spark. Remove the plug, and connect the plug wire, hold on to the insulation and hold the threaded part against the metal head or part of the engine. As you are doing this, kick start it ( 2 people) and be sure you have spark.
Old Jan 11, 2001 | 05:46 PM
Thanks to all that replied. it finally started. it only took 4 months but i have finally got my 250r i built from the frame up, running!!!!!!!!!!!!!not sure why it didn't start, guess i wasn't kicking hard enough, once agian thanks to all that replied!!!!!!!
Old Jan 16, 2001 | 11:23 AM
250Roost's Avatar
Hey if you still look at this site, how much did it cost you to build the quad , did you use mostly stock parts? just curious
Old Jan 16, 2001 | 07:38 PM
well to get it to the point where it would run with a complete engine rebuild which i did myself it cost a little less then $3000. i still have no fenders though and no seat. i already had a-arms, axle, and front shocks(all aftermarket)
