dont have a kill or ignition switch how to hot wire it
Old Dec 24, 2007 | 05:38 PM
slip15's Avatar
Default dont have a kill or ignition switch how to hot wire it
i have a 82 big red atc 200e but i have no kill or ignition switch there missing and some wires are hanging how would i hot wire it what wires do i connect??
thanks
Old Dec 26, 2007 | 06:57 PM
scary132's Avatar
You are missing the key switch or the run/kill headlight switch?
Old Dec 26, 2007 | 07:53 PM
slip15's Avatar
you just informed that i have a 185 someone else that run the vin said 200e which one is it? and i messed up on this one i have a run/off switch and a hi lo switch but no wires are connected not even to the coil which wires do i need to get it to have spark i just un froze the motor someone i got it from left the spark plug loose! i dont think i hurt anything cause it has lots of compression and turns over
Old Dec 26, 2007 | 08:41 PM
scary132's Avatar
That VIN came back as a 185. I dont think the 185 had a hi/lo subtrans though so maybe I'm wrong. If it has the hi/lo and electric start it is a 200E, or could someone have put a 200E motor in the 185 frame? I'd have to see it. If the coil and switches aren't even hooked up, you need a manual, or at least a wiring diagram. I have a 1982 200E wiring diagram I can email you if that is what you have. Mine came with all the wires diconnected too, so I know where you're coming from.
Old Mar 9, 2010 | 10:41 AM
drjoe171's Avatar
leave all those switch wires separated they only connect to kill the engine
skinnyr6
Aug 25, 2023 02:18 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
ranvette
Jul 4, 2015 06:13 PM
