07 400ex hard as hell to start in cold weather
Old Dec 25, 2007 | 10:24 AM
Dans 07400ex's Avatar
Default 07 400ex hard as hell to start in cold weather
ive heard i need to adjust my valves.atv is like new no mods
Old Dec 25, 2007 | 11:04 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You should adjust your valves just after break-in....at ~20 hours.
Hondas are jetted lean to meet emissions requirements, and the cold weather will make you even more lean. Your quad has a pumper carb, so what I do is press the throtle several times before a cold start. This injects fuel directly into the carb, and that works even better than the choke for me. Add in some choke as well, as necessary.
If you live where it is very cold it's a good idea to run a lighter oil for winter, like 5W30 for example.
Old Dec 25, 2007 | 11:12 AM
thanks
Old Dec 25, 2007 | 11:35 AM
hondabuster's Avatar
If its the valves, youd be able to verify with a compression test. Its usually the intake valve will tighten up, and the compresion will drop off . Itll start warm, but not cold.
If the compression test is good,or the valves check in tolerance, try the bigger pilot jet fix. Go with a #42 pilot, and itll start a lot easier.
article here
Also be careful with the throttle when starting, its very easy to flood that motor, and once that happens, its a real bugger to get going. So try a new spark plug , too.
If it just wont start, because of flooding or the battery wears down, just have your buddy hook up a tow strap, and bump start it.
Old Dec 25, 2007 | 03:18 PM
thanks.do you know what the compression should be with the valve problem and without.
Old Dec 25, 2007 | 05:09 PM
jrafter's Avatar
all honda are hard to start in the cold
even after rejeting my 400 with a 42 pilot jet
my rancher is fuel injected not a problem
Old Dec 26, 2007 | 12:01 PM
Bounce400ex's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Dans 07400ex
thanks.do you know what the compression should be with the valve problem and without.</end quote></div>
I have an 01 400ex and my local dealership told me 125psi means you're good.
Old Dec 26, 2007 | 09:50 PM
Gimpster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jrafter
my rancher is fuel injected not a problem</end quote></div>
If your carbed Honda is not starting good in cold weather, ditch you carb tuning personnel .... the statement of "All honda's start hard in cold weather" is untrue and misleading.
I have hundereds and hundereds of customers who will argue this issue with you after I set their carbs the correct way. No problems with cold weather start-up.
----- Gimpster -----
Old Dec 27, 2007 | 01:42 PM
oldturtle's Avatar
The only problem I have ever had starting my 04 400EX was when fuel in float bowl became stale. Now if more than a few weeks between starts I will use float drain screw to drain all old gas from float bowl. The gas in tank is always better than gas in float bowl. If starting is still an issue then the problem is most likely caused by a plugged pilot jet due to setting too long with bad gas in float bowl.
MikeyBoyesq
Nov 27, 2020 02:44 PM
DTroyer01
Jul 3, 2015 07:34 AM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
hunt365@home.com
Jul 3, 2000 11:30 PM
