50cc fully auto atv
Old Dec 26, 2007 | 10:27 PM
slugbugg's Avatar
Default 50cc fully auto atv
Could someone with one of those 50cc 4-stroke honda styled engines with fully automatic (no manual clutch-no manual shifting) tell me something.
Does it have just one geared speed or does it have a 2, 3 or 4 geared speed auto shifting trans ???.
I'm very curious.
Thanks
Old Dec 26, 2007 | 11:28 PM
onebigzj's Avatar
has a cvt trans. just like a snowmobile. has no gears just clutches. clutches react with power given to them
Old Dec 28, 2007 | 06:33 PM
spliffy's Avatar
NO it is a single geared machine if its a Honda Cloned machine, CVT would have a belt & 2 Clutches front & back with a belt running across the clutches & they change sizes & change the gear ratio...basically changeing gears for you like how a snowmobile or Polaris ATV works... The Honda clones are stuck in a gear usually like 2nd or 3rd gear & do not have a belt or change any type of gear ratios. Inmy experiance 50cc full autos like you are talking about usually have VERY bad lowend & will not climb anything... look for a 4 speed semi auto 50cc engine & run it in first or second gear & you will have plenty of power if you have the governor screwed way in.... the autos usually will not climb over your foot unless you have the governor screwed way out & then they are way to fast on the topend because they are geared wrong.
Old Dec 28, 2007 | 09:17 PM
onebigzj's Avatar
never seen one of those.
Clint Russell
Sep 25, 2015 03:20 PM
firsttimerider
Sep 20, 2015 09:07 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Hw00d
Sep 10, 2015 08:53 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
