06 Honda TRX400Fa 4x question
Old Dec 27, 2007 | 12:31 AM
IronHorseman's Avatar
Default 06 Honda TRX400Fa 4x question
Very simple question. My battery is dead so I pulled started my TRX400FA and I noticed the 4wheel drive light flashing a code. 4 continous blinks. Anyone know what this means? thanks, David from WV.
Old Dec 27, 2007 | 02:28 AM
ROTTEN ROBBY's Avatar
I don't mean to be a dork I don't know if I am asking the right place the right question but here goes, I have the same problem same year, everything. I am also looking for someone who knows what color switch assembly wires goes to red and black + & - for the winch controller. It was directly hooked up to the battery for the snow plow and it died or ran down or yikes .. Help if you can..
R.R.
Old Dec 27, 2007 | 07:21 AM
HondaMechanic's Avatar
1st. question......... code #4 is "system voltage" .. You will have to have the battery charged & load tested ..
2nd. question .... The red (+) and black (-) from the contactor go to the positive (+) and negative (-) on the battery .. If your battery is dead it should also be properly charged & load tested ..
Old Dec 27, 2007 | 02:14 PM
Gimpster's Avatar
Myself, I have not found a code 4 to lead to anything wrong, to date. Seems the code has been tripped by loose battery connections and or low battery.
Example:
If the key was left on and drained the battery, then the unit was started with the recoil starter, a code 4 would appear.
Clear the code and see if it does not come back after checking the battery like Hondamechanic mentioned
----- Gimpster -----
Old Dec 27, 2007 | 04:27 PM
Many thanks. i always get good answers from yall.
Old Dec 28, 2007 | 01:40 AM
Thank You, It worked. you guys really know your stuff!!!
Cole Hadden
Jun 15, 2025 09:05 AM
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
