Digital Display Screen (odometer) Stopped Working - Help!
Old Dec 29, 2007 | 04:13 PM
couvgrizz's Avatar
Default Digital Display Screen (odometer) Stopped Working - Help!
I have a Grizzly and was cleaning it yesterday. After I was done cleaning it the LCD digital display screen with my odometer, and hours stopped working. The back light comes on but nothing else. I don't know if I got something wet or a wire came loose. Anyone else have this problem or know how to fix it?
Thanks!
Old Jan 1, 2008 | 04:47 PM
couvgrizz's Avatar
Wanted to provide a quick update. I thought that after a few days of drying out that it would start working again, but that is not the case. The backlight still comes on but no reading.
Still hoping someone out there has encountered this before. Thank you!
Old Jan 1, 2008 | 06:16 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
Did you check your fuse for the instumentation? I believe the backlight is on a seperate fuse. I had the same problem with my old Kodiak but I forget the solution-DOH!!
Buck
Old Jan 1, 2008 | 07:37 PM
couvgrizz's Avatar
Thanks Buck - I will give that a try.
Old Jan 4, 2008 | 11:44 AM
couvgrizz's Avatar
ERROR
couvgrizz's Avatar
**UPDATE**
So after my last posting I decided to remove the display and take it inside the house to dry out in a warmer environment (quad had been sitting in cold garage). I had it in the house for four days and then decided I would give it one last try last night before going out and spending the dough ($360 or so) on a new display.
Much to my surprise it WORKED!! The hours and miles all still show and needless to say I am ecstatic. Apparently having it in the house was enough to dry out whatever water was in there. I sealed/taped the small crack that cannot be seen when the display is on the quad. We seem to be as good as new. Thank you to those who assisted!!
RIDE ON!!!
chuck1177
Jun 30, 2015 09:52 AM
big_g_squared
Jun 28, 2015 04:17 PM
Fnqrider
May 31, 2015 08:29 AM
MoJave88
Mar 6, 2001 05:39 PM
MrElussive
Oct 26, 2000 02:30 PM
