I need some tech help from a Raptor owner
Old Jan 11, 2001 | 01:46 PM
bash's Avatar
Okay, I hope some of you guys will help me out. I changed my oil and in the process, took off my skidplate. I rode my quad just a little with the skip plate off. After parking it in garage, something seemed to be missing.
I rode back through a field and found that I had dropped this http://www.metalcraft-ar15.com/hose.jpg off of it. I know it was located somewhere on the left hand side by the front sprocket, but I don't know what it hooks into. The piece on the end is a one-way valve or some sort of pressure by-pass allowing air or something to go out, but not in.
Sorry for such a silly question, I should know where this goes, but seem to be missing it.
Thanks in advance.
Oh, ps... I had someone pace me, side by side in a new truck, and my Raptor runs 72 MPH down a slight grade, everything stock but the removal of the baffle. It may have had just a tad more left, but at that point, I couldn't feel it pulling any higher. I think opening the airbox and rejetting will help on top some.
Old Jan 11, 2001 | 02:48 PM
KyRaptor's Avatar
That is the drain tube that is attached to the bottom of the carb.
Old Jan 11, 2001 | 03:29 PM
No2StrokeBs's Avatar
My friend and I ran our Raptors at the track bone *** stock, and they both ran about 75 mph
Old Jan 11, 2001 | 03:32 PM
garyc660R's Avatar
Like Kyraptor said, it's the carb drain tube. I have lost one of mine already, probably from assembly-disassembly. I'll bet 3-4 mph could be gained on top with the snorkle removed, baffle removed, and proper jetting. Or you could have laid down so far your eyes could barely peep over the tank. Yeah...that would get 3-4 mph.
Old Jan 11, 2001 | 04:00 PM
ERICsRAPTOR's Avatar
Yup Yup --the carb drain tube..seen some yellow ones couple weeks back for the raptor
Old Jan 11, 2001 | 07:41 PM
bash's Avatar
Thanks Guys!!!!
Old Jan 11, 2001 | 09:29 PM
What are u guys doing about the crancase vent tube that runs to the stock baffle when you remove it, do you plug it or what? How did you guys go about takin your carbs off? I paid the yamaha place to jet mine the first time, but now that i see im ganna have to do it a few times to get it right I need to know how.
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
