Yamaha Timberwolf
Old Jan 2, 2008 | 01:19 PM
jjmunster's Avatar
Default Yamaha Timberwolf
I have a Timberwolf that I have no idea where the vin# is located. I have found the engine #4BD-211981. I know that they made a 230cc and a 250cc, I need a new carb and do not know what size engine or what year this is. Thanks, John.
Old Jan 2, 2008 | 01:33 PM
jjmunster's Avatar
Okay, I just figured out it is a 230cc, stamped on the side of the case is 2290cm. But any idea how to find out the year? John.
Old Mar 5, 2008 | 05:56 PM
aussietimberwolf's Avatar
The vin number is stamped horizontally, into the tubular metal frame on the left at the bottom. It is directly inline with the bottom inside edge of the front left mud guard. You will need some talcum powder or chaulk and rub it into the numbers. That way you can read them.
Here is a good explaination on decoding the VIN number.
http://www.autohausaz.com/html...fication_numbers.html
If you still can't find it, tell me and I will post a picture of where it is.
Hope that helps.
Cheers.
Old Dec 21, 2012 | 03:06 PM
sturgisatv's Avatar
Default 1993 Timberwolf VIN was very hard to find...
I finally found the VIN on this 1993 Yamaha Timberwolf YFB250. It was on the frame rail on the left hand side, forward of the footpeg, on the part that angles back toward the centerline of the quad.
Mine was JY44BDA00PAXXXXXX
https://picasaweb.google.com/BlueDak...06314880346466
https://picasaweb.google.com/BlueDak...06610232228210
https://picasaweb.google.com/BlueDak...07079394131490
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
black_thunder
Sep 22, 2015 07:59 PM
Sep 17, 2015 03:06 AM
