01 raptor 660r not starting
Old Jan 2, 2008 | 03:46 PM
sdyoungsta's Avatar
Default 01 raptor 660r not starting
hi there guys my raptor is not starting anymore, i was riding it for a while popped a wheelie then it just turned off on me and didnt wan to start anymore, batteries good and when I hit the ignition to start it it just makes the ZZZ!! sound and doesnt start. so if anybody could help me with this problem thanks. and i also just clean the carb like Monday 31.
Old Jan 2, 2008 | 08:21 PM
maddog56's Avatar
The zzz sound is your one-way starter clutch failing to engage. This is almost certainly a sign that it needs to be replaced. You'll need an L&L or L&A aftermarket one-way starter clutch (because stock is junk and that's why yours failed). If you replace with another OEM part you'll just have to do it again later and it's not much cheaper.
You'll almost certainly need a new OEM 52 tooth starter gear as well, since the one-way typically chews them up when it fails. Hardened bolts for the one-way should be availible wherever you get the part, but places like rspconcepts and ripper racing have them. You'll also need a gasket for the side cover and while you're at it an oil change is a good idea to clean out whatever the one-way may have shed into the motor. A full write up on the parts you need, where to get them, and how to do the job is availible at www.raptortranny.com, just look for the one-way starter guide.
Old Jan 3, 2008 | 09:47 PM
sdyoungsta's Avatar
alright then thanks man thats what i thought it was but i wasn't really shure about it but im going to take it apart tomarrow and by all the parts i need thanks man. and the oil and spark plu change.
Old Jan 3, 2008 | 10:24 PM
2talldre's Avatar
yeah man its is 4 sure your one way clutch. I just did mine on my 02. I would get a clymers book 4 sure it helps alot. Look on e bay and you can find great deals for replacement clutch kits with everything you need to do the job. Just make sure you have a pulley puller. Good luck and happy ridin!
Old Jan 4, 2008 | 01:02 AM
sdyoungsta's Avatar
or thanks yea im going to fix that thing tomarrow and buy all the part i need also have ever done this urself is it really dificult.
Old Jan 4, 2008 | 02:21 PM
JTY2K's Avatar
I was riding one day with my 01 Raptor & all of a sudden it just killed. Tried starting it. Turned over & everything. Thought it might have something to do with the fuel system...Wrong... It was my cam chain that broke... Got that fixed & she's running once again.
Old Jan 4, 2008 | 05:22 PM
sdyoungsta's Avatar
so your cam chain broke ok well im going to have to check that also because mine turned on and i was riding it popped a wheelie brought it back down and turned of omn me and didnt want to start anymore.
Old Jan 8, 2008 | 12:39 AM
etonpartsonline's Avatar
www.raptorstarterclutch.com has the one way high performance starter clutch you need complete with lifetime warranty.
AtvManiac78
Jul 11, 2015 03:20 AM
VascoConroy
Jun 12, 2015 10:30 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
