Start in Gear - AC 250
Old Jan 12, 2001 | 12:17 PM
newbie69's Avatar
I recently purchased a new Arctic Cat 250 2x4. I have read some posts about being able to start the Arctic Cat in gear. Is there a way to make my 250 do that?
Old Jan 12, 2001 | 01:01 PM
JKB's Avatar
JKB
I think all of the newer Cats have this feature. You just squeeze the brake lever and push the start button.
Cheers Jim
Old Jan 15, 2001 | 03:53 PM
cat2504x4's Avatar
No, you can buy the kit though. Same parts as on the 300 4x4.
Hadn't thought about it so I have no clue as to what they would ask for it.
The 2wd/4wd conversion kit msrp's for 59.95 though. I know you didn't ask about it but trust me it is a good investment!
Jason
Old Jan 15, 2001 | 03:54 PM
cat2504x4's Avatar
Ignore the 4x4 kit, my eyes were not working correctly, I misread your cat specs.
Jason
Old Jan 15, 2001 | 04:19 PM
newbie69's Avatar
So are you saying there is a kit, or is it only for the 4x4?
Old Jan 16, 2001 | 09:10 PM
BONER's Avatar
The kit he mentioned will only work if you have a 250 4wd to start with.
Old Jan 17, 2001 | 01:51 PM
steven1958's Avatar
I'm not sure how the start in gear feature is wired but it could be done several ways. Run a wire from your tailight circuit to a relay. Then run a wire from the fuse box to the + in side of the relay. Then from the + out of the relay to your start switch. Or put a pressure operated switch in your brake line (it should be for a brake system)and run power to and from this switch. Clear as mud right?
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
