Rear caliper nut needed (Wolverine 450)
Old Jan 12, 2008 | 06:03 PM
jarmoore's Avatar
Default Rear caliper nut needed (Wolverine 450)
I was bleeding my brakes today and noticed that my rear caliper is loose. One of the nuts has apparently fallen off and the caliper is wobbling around. No big deal I thought, I'll just order another nut, right?
Here is the schematic on about every Yamaha OEM parts site. The part is missing! Red circle 1 shows there the nut threads on to and circle 2 is where the nut goes through. I distinctly remember it from when I replaced my brake pads. It's a tall nut, allen head. Any ideas on what I could do?
Old Jan 13, 2008 | 01:01 AM
HeftyLefty's Avatar
Take the one from the other side, and try it in the side with bolt missing. If it screws in, the threads are the same. I
f it doesn't the the missing one screws in counterclockwise. Take it to an auto parts or hardware store and have them match the length, outside diameter, and threads to a similar bolt.
Buy some Loctite, -non hardening- and put some on the bolt threads during reassembly. Torque with wrench to specs. Hit the trails.
before I go, are you sure bolt #13 is NOT the bolt you're looking for?.
Old Jan 13, 2008 | 02:38 AM
ctateusa1's Avatar
13 mounts caliper bracket to the rear swingarm. I would go to the local dealer so you make sure its the right one, they might even have it in stock to get you back on the trail. Most auto parts dealers are not gonna carry a bolt like that.
suzuki230
Jul 8, 2016 10:03 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
scaldwellk
Jun 19, 2015 05:08 PM
ragewraps
May 27, 2015 08:07 AM
