Scrambler left rear wheel locked up???
I was riding down a long steep hill using the rear brake foot pedal. At the bottom I noticed the bike acting wierd. I was dragging the left rear wheel.
I've yet to fully check it out. <u>Wanted to check in to see if there was any tips or suggestions.</u>
The crazy thing is the bike can be pushed without locking up. But under engine power it locks up.
thats weird as its a straight shaft hooked together and to have the left side dragging w/out the right. i would have said bearing but if it rolls fine w/out any power to it and cant be bearings i would think.
The only way for one wheel to lock up without the other is to have a broken axle. If it rolls ok but under load it locks, I would guess the axle is binding under load. Jack it up and try to turn the wheels, then pull the axle and have a look.
Also the pedal brake seams to have lost pressure. Could be as simple as a stuck brake. Is the rear axle solid? because it sure isn't acting like one
i agree. may be just the break may be looked up. .....................shea.................
P.S.ryker77--- oooooooooooooooooooooorrrrrrrrrrraaahhhhhhhhhhhhhh hhhhhhh!!!!! Devil Dog
Seems impossible to only have one wheel lock up.
- Straight solid axle
- single brake controls the axle.
Seems like a broken axle. Don't push, pull or try to drive the quad, if the axle is broken you could damage the rear housing.
Chocobamofo
Jul 10, 2015 07:46 PM
