Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
c'mon all you people
Old Jan 15, 2008 | 01:01 AM
onlybg21's Avatar
Default c'mon all you people
no body on here knows how to remove the front sprocket on a lakota?
Old Jan 15, 2008 | 02:01 PM
deanz400's Avatar
move the locking ring and loosen the nut
Old Jan 15, 2008 | 05:29 PM
onlybg21's Avatar
what exactly is the locking ring? is it behind the nut? and how to you move it? because on mine its just a nut and some kinda washer type thing behind that. then the sprocket. i've heated it and tried to loosen it, used a breaker bar...tried turning both ways....i dunno
Old Jan 15, 2008 | 07:16 PM
Wendyosworld's Avatar
The lock is behind the nut. You have to bend the tabs up then loosen the nut. The nut has regular threads. Someone might have it on real tight , so have someone hold the brake to help. Or use a air impact wrench that will break it loose.
Old Jan 16, 2008 | 07:31 PM
onlybg21's Avatar
now, by bending the tabs up you mean ? cuz like the tab is flush with the sprocket currently, should i bend it so that they bend towards the nut? an impact gun is the only thing i havent tried. and is there a specific gear i should have the tranny in? reverse, 1st, or neutral? yah sumone definatly put this together very tightly..lol
shimanok2
Jan 29, 2016 07:37 PM
kbazzy
Sep 26, 2015 11:26 AM
Irishman301
Sep 23, 2015 01:47 PM
01ssls1
Sep 22, 2015 06:50 AM
Elkaholic
Sep 6, 2015 02:44 PM
