Help! 06 polaris 500 electrical concern
Old Jan 15, 2008 | 11:53 PM
ford1's Avatar
Default Help! 06 polaris 500 electrical concern
The electrical system cuts in and out causing the lights to flicker and the atv to stall. The atv will not run for more than 10 seconds but will start right away. I've eliminated any battery concerns. Any ideas?
Old Jan 16, 2008 | 08:08 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
how did you eliminate the battery? what is the voltage reading when its running or when its sitting there off. another thing it could be is the emc is bad.
Old Jan 16, 2008 | 09:12 AM
Kerbbirds's Avatar
Check all the connections at the selenoid, they tend to get dirty or loose, if thats not it, probably the ECM,they seem to have problems, some were recalled.
Old Jan 16, 2008 | 05:44 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
If it stalls when the lights are turned on ..BAD ECM.........I had the same trouble........
.......Caper...........
Try starting the Quad up without the light switch on.........Then turn the lights on and see if it stays running!!.....
skinnyr6
Aug 25, 2023 02:18 AM
Nondem
Feb 22, 2020 12:20 PM
chammerbeck
Jul 17, 2015 08:06 AM
Unzzy66
Jul 11, 2015 10:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
