SunL/Hanma 110 gearing and clutch...
Old Jan 17, 2008 | 05:25 PM
rockcrawlerdude's Avatar
Default SunL/Hanma 110 gearing and clutch...
i got my son SunL/Hanma 110 with a single speed auto clutch. it seems to be geared too tall as it gets stuck easy in loose sand/dirt or going up long hills. does any place sell different sprockets for these? i was thinking the pit bike folks might have something for it BUT they use 420 chains and this atv uses 428 so unless 1) the splines are the same and 2) the rear bolt patter is the same i could swap out both sprockets and chain for that to work. but id rather just change out CS sprocket for now and then go to the other if that wasnt low enough. i dont mind giving up top end for better hill climbing soft terrain driveability...if not then is the clutch adjustable where you can stall the engagement to engage at a higher rpm which would help this prob.... thanks IN advance...N8
Old Jun 17, 2008 | 08:29 AM
TurboDiverArt's Avatar
I have the exact same question you asked. Did you ever figure out how to get a smaller CS sprocket or larger rear sprocket? If so, where did you get it? How about delaying the clutch lockup?
Thanks,
Old Jun 17, 2008 | 12:14 PM
i actually got a 12t cs sprocket for a klf 110 which is a kawasaki mojave 110 from rocky mountain atv or one of the other big websites. now in theory it fits BUT i guess irregularities in the chinese parts i had to slightly widen the grooves on the sprocket with a dremel tool. after a bit of trial and error i finally got it to where it will fit! it works awesome!!! i didnt even have to mess with the clutch as it grabs with no prob. i will say that it does give up some of the top end which for when my son is riding is okay by me BUT when i ride it to mess around on i guess im used to going a little faster so it seems slow but like i said for a kid its good enough... let me know if you have any more questions.... N8
Old Jun 17, 2008 | 12:41 PM
Hey, that's great. Thanks for the quick reply. I think the 12-tooth sprocket is the ticket for what I'm looking for. I'll look for one myself.
How did you attach it, same as the stock one? Were you able to use the 2 keeper bolt holes in the sprocket and still clear the chain?
Art.
Old Jun 17, 2008 | 02:16 PM
yea i was able to use the stock retainer and bolts because the new sprocket had the bolt holes in it but if it didnt a simple c or e clip would have done the job as well...
Old Jun 17, 2008 | 02:39 PM
link for front sprocket....
Old Jun 17, 2008 | 04:21 PM
Sorry to keep asking questions. The picture doesn't match the actual sprocket, right? The picture shows a fine-toothed CS while the one on my Hamna is a 6 square-toothed shaft. Just want to double check first.
Art.
Old Jun 17, 2008 | 05:08 PM
no the pic isnt the same, the pic is just a file photo. but yes thats the one i ordered...
Old Jun 17, 2008 | 05:21 PM
luvmysxs's Avatar
chinese 4 stroke 50-110cc engines are honda clones, not kawasaki. check this sellers store for the amount of teeth you're looking forchinese quad spockets
Old Jun 17, 2008 | 05:36 PM
they dont make a 12 tooth for the them and i wanted a 12 tooth for safety, ability to climb hills and run in loose sand the KAWASAKI MOJAVE 110 has a 12 tooth sprocket that WILL work and thats what i run....
