2006 Honda TRX90
Old Jan 19, 2008 | 12:01 AM
breck's Avatar
Default 2006 Honda TRX90
This quad was bought brand new, my son rode it for about a year stock. This year for Christmas Santa got him a Pro-circuit pipe and K&n airfilter with precharger. I put the parts on and took the airbox lid off. The quad now stalls when my son goes from an idle to full throttle. This didn't happen with the stock parts on. Can someone tell me what is causing this? There is also no change when I put the airbox lid back on. Do I need to change the jets, if so what size? I contacted Pro-circuit who advised me to leave the jets stock.
Old Jan 19, 2008 | 12:05 AM
onebigzj's Avatar
I would adjust the fuel air mix. how does it idle? if we cant figure it out I would call santa!
Old Jan 19, 2008 | 02:09 AM
breck's Avatar
It idles fine.
Old Jan 19, 2008 | 12:31 PM
smb05's Avatar
breck,
You need to richen up the needle. The needle and needle jet are the components that primarily regulate fuel flow between 1/8 and 3/4 throttle. Move the e-clip down one or two spots on the needle.
Good Luck.
SB.
Old Jan 19, 2008 | 04:07 PM
Quad Challenge's Avatar
Hi, there is only one position on the needle on a TRX90 06/07. I would agree the needle needs richening up, but the only way would be to put a small washer under the clip to raise it up a little.
Good luck !
Old Jan 19, 2008 | 04:34 PM
smb05's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Quad Challenge
</end quote></div>
Great suggestion Quad Challenge, I did not know the needle did not have adjustment rings on it.
If that is the case then a small washer from your local hardware store will work just fine. Match up the washer size with the e-clip or in my situation another washer on the needle.
I had to do the same thing on the Chinese quad we had. I used very small brass washers from my local hardware store, worked great.
SB.
Old Sep 29, 2008 | 01:13 PM
Lovemy450's Avatar
Default 2006 Honda TRX90"></title><script src=
I realize this is an old post, but I have the answer to your question. The TRX90 is very lean from the factory. That's why it is so cold natured. When you put the pipe on you made it even leaner which is what's causing your problems.
Go to Powroll.com, they have a jet kit specifically for the TRX90 that comes with 3 jets and the washer for placing under the needle-clip. Use the 92 jet, anything more and you are making it too rich. The other jets included with the kit are for boring-out mods and such.
This cheap fix ($25) takes away the cold starting, and really adds to the horsepower and torque. Huge improvements all around.
Good luck.
Old Jan 23, 2012 | 01:25 AM
jedijingle's Avatar
Hello Love My 450, I just picked up one of these bikes for my son and for the life of me cannot keep it idling with have the choke partially on. Will this Powroll kit work with a stock bike? Thanks In advance. John
Jazperman
Aug 7, 2016 08:12 PM
cody500ho
14
Aug 14, 2015 05:03 PM
greek271
Aug 8, 2015 08:16 PM
Jul 22, 2015 05:00 AM
hondarider1234
Jul 21, 2015 11:53 PM
