lunging forward
I just replaced the belt on my Sportsman 335 and it seems to want to creep forward at idle. Just curious what might cause this. Also, is there a simple fix for the belt cover to stop rubbing. It seems loose even with a new seal. Thanks in advance. BTW, I am a new member, but often reader.
is it the correct belt, is the words facing froward so its going the right direction(dont know if it makes a big diff or not) is the engine out of align. some times you need to either pull up or push down of=n the cover to stop it from rubbing.
According to the local Polaris dealer, it's the right belt. I do not about the direction, doesn't seem like it should matter though. I'll check the idle, sounds like that could be it. Thanks again.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
