Homemade plows??
Old Jan 21, 2008 | 10:13 AM
700 sportsman's Avatar
Default Homemade plows??
What do you guys think of making a homemade plow? Any suggestions would be appreciated.
Old Jan 21, 2008 | 07:30 PM
BradW's Avatar
Well, it's a hell of a lot cheaper than buying one. I put one together for about $75. I didn't have to buy the blade though. And I definitely over-built mine. I didn't realize how flimsy the store-bought ones were until after I made mine out of 1/4" thick, 3"x4" angle iron. I guess the fact that the push-carriage is stronger than the frame of my quad means that it'll last quite a few years.
Old Jan 21, 2008 | 08:05 PM
Force's Avatar
Seen alot of homemade ones and they look like it but they work.Most people tend to over build these and as a result they are to heavy and hard on the front suspension.
Old Jan 21, 2008 | 09:14 PM
have any pics brad??
how did u go about making the blade
Old Dec 22, 2008 | 05:41 PM
hondaRancher123's Avatar
Default Homemade plows??"></title><script src=
a simple way of making the blade would be getting one of those 55 gallon metal trash barrels. ( the kind you see at public fields) Then you cut the trash barrel in half and you you yourself a perfectly curved plow, that is also very sturdy.
Old Dec 22, 2008 | 06:00 PM
I already bought one, thanks though
Old Dec 28, 2008 | 12:00 PM
vinny04's Avatar
people around here get old water heaters 40gal is the norm and cut out a section with the grinder also them cut them from old furnace oil tanks (cut out the bottom). most run C-channel to the rear and hook it to the ball with coupler. also have a plate on the front frame with U-bolts that has a place to slide a pin through to keep the front up. Raise and lower with winch.
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
