TCS shocks, how much shorter are they for the Raptor?
Old Jan 13, 2001 | 12:09 AM
Bartman's Avatar
CT Racing sells TCS shocks for the Raptor. They say that they are shorter all around and that it helps the Raptor in handling. How much shorter are they in the front and rear than stock shocks? Anybody know? And, will the TCS shocks work with the TimmyBoy a-arms or are they for stock a-arms only? Why couldn't a guy just buy some shocks that fit say a Blaster and make it sit lower?
Old Jan 13, 2001 | 12:25 AM
chasman's Avatar
I don't think the blaster shocks would have the travel that you would need. They did an article in dirt wheels on the modified raptor that had timmy boy a arms with tcs shocks. I think it lowered it an inch or two, not totaly sure though.
Chasman
01 blk/wht raptor
Old Jan 13, 2001 | 08:53 AM
bash's Avatar
I think the overall body length is shorter, but the stroke is longer, so you still end up with more wheel travel.
I rode with KyRaptor yesterday and his sit quite a bit lower with the TCS shocks.
Old Jan 13, 2001 | 09:14 AM
badchad's Avatar
I've read that the TCS shocks with the Timmy boy a-arms lowered the Raptor 1 1/2" while attaining more wheel travel....somewhere in the 11 1/4" range...sounds like the way to go! I have also been told that the rear shock can be rebuilt with a TCS conversion to gain wheel travel and to help the quad sit lower. That sounds like the hot set up to me. Dirt wheels did an article comparing it to the DS 650 with some mods and they said the Raptor handled like a pro level race quad with the modifications. The MX circuit should be interesting this year!!
Old Jan 13, 2001 | 11:25 AM
badraptor's Avatar
i got the tcs on the front of my raptor with plus two arms and had a conversion done on the rear, i sold the stock shocks so i can't realy compare them now but the raptor sits down an inch or two now . i wanted it to be slammed like my ohlins on my 310r so i called tcs and they told me to ride it for a while then do the adjustments after they break in, both the front and rear are ride height adjustable , and it rides like a dream,i rode a tcs equipped 440 ex fell in love with the way it handled and then i went home and called tcs and ordered mine, $750 front,450 rear conversion,you can get them cheaper if you shop around
Old Jan 13, 2001 | 12:06 PM
bash's Avatar
How much are used Raptor shocks bringing these days? I may sell mine.
Old Jan 13, 2001 | 12:10 PM
bash's Avatar
one more thing, how much stability do you think the TCS shocks would add if you didn't get wider a-arms?
Old Jan 13, 2001 | 12:22 PM
KyRaptor's Avatar
The TCS shocks for mine are actually an inch and a quarter longer than the stock shocks, not shorter. I have Lone Star +3 a-arms. So mine are for extended a-arms which brings the travel to over 13 inches. The TCS shocks for the stock a-arms bring the travel to over 11 inches. The stock shocks travel is around 9 inches.
How TCS lowers the quad is set the sag height to around 50% of the travel. Where the sag height on the stock shocks is set at around 30%. But the stock shock raises or lowers the sag height using pre-load on the stock which softens or stiffens the ride. So to lower the quad you have to take the pre-load off which makes the ride spongy. If you raise the quad you have to add pre-load which makes the ride stiff.
How they lower the quad is by using that extra amount of travel and using it to lower the ride while keeping the effective travel about the same.
You can adjust the sag height on the TCS shock by adding or removing spacers located under the gold spring.
I removed one of the spacers and it lowered the quad to mx height. But I discovered is not that great for trail riding after riding with Bash. I will have to put the spacer back in for the trails.
Old Jan 14, 2001 | 02:43 PM
aggromoose's Avatar
who has the cheapest prices for the tcs. K&k used to have them for 650 but are now 749. 450 for rear conversion. Is there any better prices than 750 and 450.
bmxatv10
Oct 14, 2022 06:23 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
