Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
electrical problems
Old Jan 27, 2008 | 04:34 PM
devill's Avatar
Default electrical problems
2002 350 honda fourtrax 4x4 has blown main fuse.replaced it while ignition was turned off and it blew.the bike will start with pull cord with out a fuse.while bike is running i can put in a new fuse and the neutral and oil temp lights and the digital dash will flash on and off and sometimes when i turn on headlight switch the engine will shut down......please any suggestions would be appreciated...thanks
Old Jan 27, 2008 | 07:09 PM
devill's Avatar
could the regulator cause these problems???
Old Jan 27, 2008 | 07:49 PM
JeffinTD's Avatar
Possibly.
Do you have a volt/ohm meter?
Actually, probably the fastest way to tell would be to disconnect the regulator plug, and replace the fuse again while the key is off.
If it still immediately blows the fuse with the key off, I'd say you have a short in the harness or problem in the key switch.
On the other hand, if it blows the fuse when you replace it with the key off and the regulator connected, and it doesn't blow the fuse when you replace it with the key off and the regulator disconnected, then I think it would be safe to say the regulator is grounded out...
The thing about turning on the headlight causing the motor to die kind of concerns me, but I'd assume if there was a short in the lighting system, it would blow that fuse.
Old Jan 28, 2008 | 11:56 PM
devill's Avatar
my buddy got a 450 foreman(1999) just wondering if the regulator from his bike would be ok to try on a 350 fourtrax(2002)as a new one will cost me $140+ canadian.just to make sure this is my prob?????
Old Jan 29, 2008 | 12:08 AM
JeffinTD's Avatar
Did you try unhooking the regulator and putting in a new fuse to see if it blows?
Old Jan 30, 2008 | 12:11 AM
devill's Avatar
with the regulator plugged in my dash dosent light up and with the regulator unplugged it lights up just fine.......whats goin on here....not blowin fuses anymore....soooo??????? not to sure anymore......
Old Jan 30, 2008 | 12:28 AM
JeffinTD's Avatar
Do you have an amp meter? If so, try measuring current draw from the battery with the key and everything off, both with the regulator hooked up, and with it unhooked...
Old Jan 31, 2008 | 06:08 PM
devill's Avatar
when i p-lug in the regulator the voltage drops by 2 volts and it gets as hot as the flames of hell...
Old Jan 31, 2008 | 11:25 PM
JeffinTD's Avatar
Shorted or grounded winding in the alternator coil?
Old Feb 7, 2008 | 10:32 PM
devill's Avatar
hey ....i got a new regulator(contactor) and now my 350 trx is workin just fine. the new part cost me $151.35 canadian. thanks for the suggestions
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
