2005 350 raptor problem
I have a 2005 yamaha raptor 350 SE that my little brother put the battery charger on backwards. Since then we haven't been able to get it started with or without the charger hooked up (correctly, this time). I don't have the owners manual with it, but I figured there are some fuses somewhere that will need replaced now and possibly the battery is bad now? I was wondering if anyone else had some insight on this issue. Any help is well appreciated.
Thanks,
Parker
Thanks,
Parker
I believe it was only left on for a few minutes, but I wasn't there when it was done. We had usually just been using it to get the atv started, so once they couldn't get it started with the charger on backwards, I'm hoping they removed it and thats when they came inside and told my dad. Thanks for letting me know about that fuse though, I would have tore that thing apart looking for it probably.
The fuse on the Raptor 350 is actually under the seat in front of the battery: It's a plug-in automotive style fuse.:http://www.ronniesmailorder.co...che_section_detail.asp
Well that didn't quite take youto the right place, but you can select your bike and select electrical1 and that will be a layout of the Raptor 350 electrical components. Completely different than a Warrior.
