Wolverine hard shifting
Old Jan 13, 2001 | 07:22 PM
derekjes's Avatar
My '96 Wolverine has been really hard to shift lately, and I mean REALLY hard. It doesn't do it in every gear, but it does it once & a while. Reverse, for example, is almost impossible to get into gear. I have to put almost all my weight on the shifter to get it to click into gear. It's also done it in 1st and 2nd gears too, but not always. Does anyone know what could be causing this? I don't have the cash to take it to a shop right now, and I'd hate to have to lay the bike up until I can afford to fix it. Could it just be the clutch adjustment or something?
Old Jan 13, 2001 | 09:07 PM
macgiver's Avatar
check your oil level and maybe adjust your cluch. they get hard to shiift when the engine oil is low
Old Jan 14, 2001 | 10:10 AM
1clnwolverine's Avatar
I adjusted my clutch and turned my idle down a little and this help out.....
Old Jan 14, 2001 | 10:05 PM
derekjes's Avatar
I already thought about the oil problem, so I changed it. I was running 20W50 in it, but it's winter time now, and temps here get down to around -25c, so I put 5W30 in it. The problem is still there. As far as the idling speed goes, it is shifting just like it does when the idleing speed is turned up too high, and normally I would think that this could be the problem, however, it also does it when I'm driving at higher speeds, and going through the gears, so the idleing speed wouldn't be a factor there.
Ridgerunner665
Sep 15, 2015 01:20 AM
bvolks
Sep 13, 2015 12:57 PM
essonlaker
Sep 10, 2015 01:12 PM
Elkaholic
Sep 6, 2015 02:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
