Electrical diagram Polaris 500 98
Old Feb 6, 2008 | 08:48 AM
used2surf's Avatar
Default Electrical diagram Polaris 500 98
Hi Guys, I'm new to the forum and have just inherited a 98 sportsman that has been sitting for the last 4 years. The over ride switch seems to work in reverse in all gears ie when not depressed the motor is governed and when depressed the motor reves freely. I'm assuming its in the wireing, any ideas and or has someone out there got a wireing diagram.
Cheers from Western Australia, Bob
Old Feb 6, 2008 | 01:04 PM
floodrunner's Avatar
Welcome to the forum Bob. I'd like to help you out but can't really tell from your description what's going on. If your problem is with the rev limiter you should be able to disable it by cutting the gray/orange wire that goes to the speedometer (for diagnostic purposes only, hehehe). Hope that helps.
Old Feb 9, 2008 | 09:44 AM
used2surf's Avatar
Thanks for the quick response, but thats why I need a circuit diagram, as I have no wires going into the speedo! My bike won't rev in any gear unless the o/r switch is depressed. Maybe the reverse sensor is jammed on? any other ideas. Cheers Bob
skinnyr6
Aug 25, 2023 02:18 AM
chammerbeck
Jul 17, 2015 08:06 AM
Unzzy66
Jul 11, 2015 10:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
tweeder
Jul 5, 2015 01:57 PM
