Foreman ECU
Old Feb 9, 2008 | 06:54 AM
Capt. Bob's Avatar
Default Foreman ECU
Where is the best place to order an ECU for a 07 Foreman FE? The dealers don't have any in stock and I can probably get one cheaper online anyway. Thanks
Old Feb 9, 2008 | 07:28 AM
HondaMechanic's Avatar
Default Foreman ECU
Why do you need a new ECM ..?
Old Feb 9, 2008 | 07:56 AM
Capt. Bob's Avatar
Default Foreman ECU
Because the cooling fan will not go off even when the motor is not running and the ignition switch is on.
Old Feb 9, 2008 | 08:11 AM
700 sportsman's Avatar
Default Foreman ECU
id try ebay
Old Feb 9, 2008 | 08:18 AM
Capt. Bob's Avatar
Default Foreman ECU
Been there done that.
Old Feb 9, 2008 | 01:28 PM
hondabuster's Avatar
Default Foreman ECU
Id wire in a switch, and go full manual on the fan control.
Have you run thru the diagnostics and it fingered the ecu?
Old Feb 9, 2008 | 04:12 PM
Gimpster's Avatar
Default Foreman ECU
As I mentioned earlier today to someone else, try Ronnie's Microfiche
The list price from them for an electric shift ECU is around $209 and for the foot shift is likw $192.
They can be ordered from them
Too bad I am not at work, I could check my cost on one from Honda
----- gimpster -----
Old Feb 10, 2008 | 07:21 AM
Capt. Bob's Avatar
Default Foreman ECU
<span class="FTHighlightFont">Id wire in a switch, and go full manual on the fan control.
Have you run thru the diagnostics and it fingered the ecu? </span ft>
I went through the test procedures just like the Honda service manual says. The dealer even thinks it is the ECU but Honda won't replace it untill the dealer does the same tests and keeps it a week before they will send the part. The dealer can't get to the procedure right away and that leaves me without the machine for up to two weeks. Also I would have to take it in, leave it and then go back and get it.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
highwayman
Sep 19, 2015 12:59 PM
patrick.oc123
Sep 15, 2015 02:45 PM
