Air box oil
Old Feb 9, 2008 | 06:53 PM
aviman9's Avatar
Default Air box oil
I asked earlier about oil in my air box, and the suggestion was to check the oil level. The oil level was fine but i found both plastic valve covers loose, one was completely off. The one that was off will not tighten down. I am assuming that this was pressurizing the case, am i right? Compression check read 70 psi!
Did the plastic valve covers shrink because of the heat?
2000 325 magnum
Old Feb 9, 2008 | 10:02 PM
sheepdogMSP8117's Avatar
Default Air box oil
http://forums.atvconnection.co...id/11/threadid/536082
Your valve covers are plastic??
Old Feb 9, 2008 | 10:45 PM
aviman9's Avatar
Default Air box oil
Yep one on the front and on the back. Big screw on type!
