diference between 200es and 200x (engine)
Old Feb 9, 2008 | 09:43 PM
prescott69's Avatar
Default diference between 200es and 200x (engine)
je veut savoir si je peut transformer mon 200es en 200x.(moteur)
Old Feb 16, 2008 | 07:35 PM
lawnboymelvin's Avatar
200x is racing and is kick start 200es is utility and electric/pullstart and shaft drive. you cannot put a 200es engine in a 200x frame as it is not shaft drive. same with the 200x motor it cant go in the 200es cause the 200es doesnt have chain. hope this helps.
melvin
Old Feb 16, 2008 | 10:12 PM
prescott69's Avatar
ok thank but can i put the camshaft,piston of the 200x on 200es
Old Feb 16, 2008 | 10:14 PM
yes i beleive the cam shaft is the same size. for the piston as long as both engines are stock most parts are interchangable. if you have to you can use the top end from the 200es on the 200x and that would work.
melvin
Old Feb 16, 2008 | 10:32 PM
prescott69's Avatar
no i have a 200es and i will buy new parts of 200x to put in it to get more power in my 200es
which part do you suggest
thx a lot
Old Feb 16, 2008 | 11:07 PM
probably the cam and if you could get the 200x piston and rings that might give it a bit more power. also the 200x carb would be good as i had that on my 200es and it gave it a bit more kick lol
Old Feb 16, 2008 | 11:40 PM
customtrikes's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: lawnboymelvin
probably the cam and if you could get the 200x piston and rings that might give it a bit more power. also the 200x carb would be good as i had that on my 200es and it gave it a bit more kick lol</end quote></div>
Make shure you have a good pipe and jet if you do those mods.
Old Feb 16, 2008 | 11:44 PM
prescott69's Avatar
the parts of xr200r is it good for 200es?(cam spring, piston)
xr200r parts is it better than 200x part for 200es?(cam spring, piston)
Old Feb 17, 2008 | 12:08 AM
im not sure ive never owned an xr200r but i assume they are
Old Feb 17, 2008 | 12:09 AM
<div class="FTQUOTE"><begin quote>Originally posted by: prescott69
xr200r parts is it better than 200x part for 200es?(cam spring, piston)</end quote></div>
The only thing I have done was the 6 speed xr200r trany.
Can't help you on the other parts swap you are asking about.
