diference between 200es and 200x (engine)
200x is racing and is kick start 200es is utility and electric/pullstart and shaft drive. you cannot put a 200es engine in a 200x frame as it is not shaft drive. same with the 200x motor it cant go in the 200es cause the 200es doesnt have chain. hope this helps.
melvin
melvin
<div class="FTQUOTE"><begin quote>Originally posted by: lawnboymelvin
probably the cam and if you could get the 200x piston and rings that might give it a bit more power. also the 200x carb would be good as i had that on my 200es and it gave it a bit more kick lol</end quote></div>
Make shure you have a good pipe and jet if you do those mods.
<div class="FTQUOTE"><begin quote>Originally posted by: prescott69
the parts of xr200r is it good for 200es?(cam spring, piston)
xr200r parts is it better than 200x part for 200es?(cam spring, piston)</end quote></div>
The only thing I have done was the 6 speed xr200r trany.
Can't help you on the other parts swap you are asking about.
