Sport Quads Discussions on sport quads.
Honda 250X steering weird
Old Feb 11, 2008 | 02:17 PM
330X=]'s Avatar
Default Honda 250X steering weird
Hi, I just noticed that my wheeler is steering REALLY weird. When I turn it, the left wheel goes, but the right one hesitates for a second until you turn it further. [img]i/expressions/face-icon-small-disgusted.gif[/img] That same right side tire also leans a little bit while the other side is straight. It leans with the top toward the center of the quad. Any ideas? Tie rod adjustment or something like that? Any help would be greatly appreciated. Thanks a lot! [img]i/expressions/beer.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 11, 2008 | 03:44 PM
hondabuster's Avatar
The tie rod end could be sloppy or loose, but it sounds like one of the a arms is screwed up, because of the camber change. Jack it up , and start wiggling things on that side, it should be easy to see what part has too much slop in it. Everything should be firm and snug, and nothing should clunk or be loose.
Dont ride it anymore, until it gets fixed, because if it lets loose all at once, someone could be headed straight on into a tree or something.
Old Feb 11, 2008 | 06:27 PM
330X=]'s Avatar
Well, I did what you said, and it turns out that the tie-rod was loose. I tightened it up, and it seems to be fine now, but it still leans. It's been leaning for a while, since I got it about a month ago, but I didnt think it mattered enough to fix it. How do you change the angle of the tires? Loosen those bolts on the tie-rod and unscrew it or screw it in more, then tighten things back up again? [img]i/expressions/face-icon-small-confused.gif[/img] Thanks for the help.
Old Feb 11, 2008 | 06:28 PM
330X=]'s Avatar
Oh yeah, it has a 400ex front end if that matters.
Old Feb 12, 2008 | 02:35 AM
unless its an aftermarket a arm, it cant be adjusted for camber.
Old Feb 12, 2008 | 02:23 PM
330X=]'s Avatar
Well, its not stock, but it is. haha. So adjusting the tie-rod wont do anything but lead to a headache then? Okay, I guess I'll just ride it as is. Thanks guys.
Old Feb 12, 2008 | 02:24 PM
330X=]'s Avatar
ooops, my bad, thanks hondabuster. haha
Nondem
Feb 22, 2020 12:20 PM
Aug 6, 2015 11:49 AM
ghost civic
Jul 27, 2015 03:15 AM
hondarider1234
Jul 21, 2015 11:53 PM
Scottma518
Jul 10, 2015 12:42 AM
