Running your engine too lean?
Old Jan 3, 2000 | 10:45 PM
dominator's Avatar
Quick question, adding a aftermarket pipe to a 2 stroke engine will make the Air fuel ratio leaner or richer? I would guess leaner becuase of the increased air flow. Right? How much would a aftermarket pipe effect jetting? Would it make it too lean and ruin the engine? Would starting with a few jets richer that stock be a good place to start?
How does performance reed valves, porting and increased compression effect jetting?
Thanks in advance
Old Jan 3, 2000 | 11:03 PM
hot_shoe_cv's Avatar
Dominator,
Yes, a pipe will usually require rejetting your main. Since pipes & silencers vary greatly in design and purpose,& since elevation & temperature affect jetting, it's difficult to say how fat you need to go. I would go to 2 sizes fatter and test ride at 3/4 or better rpms, then do a plug read,. If it indicates rich then you can drop one size. It's always better to be on the rich side when testing as no harm can be done to the engine that way. Main jets are quite inexpensive so it is always good to have several sizes in your tool box.The other modifications you mentioned may call for a fatter mixture also, especially the reeds
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 01-03-2000).]
SOLOLUCKY
Oct 4, 2024 09:09 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
scaldwellk
Jun 19, 2015 05:08 PM
