Help wiring a 82 honda ATC 70?
Old Feb 13, 2008 | 01:34 AM
notyepcars's Avatar
Default Help wiring a 82 honda ATC 70?
Inherited a 82 atc 70 basket case, missing alot of parts. There are two wire coming out of the on/off switch, green w/ring terminal and a black (male spade), where do these go? Out of the engine there are three wire, a black (female spade) and a green and brown wire that go into a small junction block, and out of that there is a black (male spade) wire, where does this go? Little confused looking at some wiring diagrams. Thanks guys.
Old Feb 13, 2008 | 11:12 AM
scary132's Avatar
www.glamisdunes.com has a great ATC70 area, plus they have a manual you can download.
Old Mar 30, 2008 | 01:42 AM
bluelu00's Avatar
The green wire with the ring from the on/off switch goes on one of the bolts that holds the coil on (or any ground), and the black connects to the black wire on the coil which also connects to the female spade coming out of the motor.
Scottma518
Jul 16, 2015 09:19 PM
Unzzy66
Jul 11, 2015 10:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
tweeder
Jul 5, 2015 01:57 PM
D-Hagz
Jul 4, 2015 02:19 AM
