Rim size/bolt pattern
Old Feb 15, 2008 | 11:08 AM
slikjr's Avatar
Default Rim size/bolt pattern
I'm going to be buying a set of rims for my 2005 Sportsman 400. Does anyone know the rim size/dimensions and the bolt pattern for them.
In other words, what do I ask for when I go into the store so I don't look like an idiot. I'll do that on here, then when I go in...I'll save face ahahah.
Thanks for the help!
Old Feb 15, 2008 | 12:59 PM
OIown12's Avatar
The width and diameter should be stamped on the wheel. Mine is 12x7. That means a 12" diameter and 7" width. The standard Polaris bolt pattern is 4/156. That means that there are 4 lugs and two opposite of one another have 156mm between them. Standard offset is 4+3 (notice that 4+3=7, the total width of the rim). 4 is the off center inside measurement and 3 is the off center outside measurement (in inches).
A good tire shop will be more than willing to help.
Old Feb 15, 2008 | 02:25 PM
slikjr's Avatar
Hey, thanks a lot!! Most excellent. I appreciate you sharing your knowledge.
blueandy88
Sep 7, 2020 03:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
EIF
Apr 20, 2017 07:15 PM
blueandy88
Aug 30, 2015 08:26 PM
XxS0ccerstarxX
Aug 27, 2015 02:31 PM
