intermittent spark on 1987 trx350d
I have intermittent spark all of the time. When it is cold i can pull the plug hook it up to the lead, ground it and it sparks a couple times then misses. there is no set number of sparks before it misses. Bike will sometimes start and run for about an hour and then die. it will start again after a little while but unless you keep the revs up high it will die again
fordfaithful21
Dec 7, 2015 05:52 PM
1987, 350, atv, cold, honda, intermitten, intermittent, intermittently, spark, sparks, start, trx, trx350d
