600 Twin has coolant leak
My 600 twin has developed a coolant leak. Near as I can tell it's coming from the water pump housing area. I am hoping it's just a seal.
Anyone have this problem before? Did you fix it yourself or have a Tech do it?
Any help is appreciated.
That is a know problem on the 600 Twin, I have a 2003. The original covers on the waterpumps warp and leak, there is a new cover that supercedes the original that is aluminum and wont leak.
The clamp is good and it's not leaking from the hose, but I will replace the clamp anyway.
I'm not sure about a weap hole but the fluid is definately coming out of the housing area.
I will check on the aluminum cover, I think the one thats on it is black plastic.
Thanks for all the replies, this forum is the shizznizzledizzle.
Beer Truck: I have the same machine, sure would like to know whats causing the leak. If it turns out to be the cover, is it plastic? If you fix it, is the new replacement cover aluminum? Thanks Much
Dennym100
Dennym100
Dennym100:
I plan on looking at it this weekend and I'll let you know. I am hoping for the best.
OK, I took off the cover. It is plastic and has a rubber o-ring type gasket. Can't tell if it is warped but the gasket is compressed enough that it is flush with the cover, I don't see how it was ever making a seal.
I will try putting some gasket sealer on it and reinstalling. Anyone have opinion on this???
<div class="FTQUOTE"><begin quote>Originally posted by: BeerTruck
I will try putting some gasket sealer on it and reinstalling. Anyone have opinion on this???</end quote></div>
I have one of those o-ring gaskets brand new in the packet. PM me if your interested in it.
