Pure Polaris exhaust
Old Feb 18, 2008 | 03:17 PM
polarisman600's Avatar
Default Pure Polaris exhaust
i was thinking about getting the pure polaris exhaust by white brothers for my sportsman 600. whats everyone think about this pipe, good or bad? also how hard would it be to install it? would i need to rejet after putting the pipe on? i already had a jet kit installed and was wondering if i would need to rejet.
Old Feb 18, 2008 | 07:04 PM
anyone??
Old Feb 18, 2008 | 09:10 PM
nickatnite's Avatar
what is the jet kit for a air filter?
Old Feb 18, 2008 | 09:26 PM
its for the air filter and also it improved some starting issues.
Old Feb 18, 2008 | 09:30 PM
nickatnite's Avatar
i dont think you will need to rejet. i have the dynojet too and i am going to put a HSP exhuast on tuesday. so ill tell ya about it later. polaris come rich from factory so i dont think there is a need to.
Old Feb 18, 2008 | 09:31 PM
nickatnite's Avatar
it all depends you might not. you might have to?
Old Feb 18, 2008 | 09:34 PM
SPORTSMAN70003's Avatar
I have a white bros. which is the same thing as the pure polaris exhaust and like it. You can add or remove disc for more power. Less disc the better bottom end will be and the more disc the better top end will be. Keep in mind the more disc you add the louder it will be. You might also need to add a bigger main jet depending on how rich your jetting is right now.
Old Feb 18, 2008 | 09:38 PM
you can tell by the way that its running if you have to rejet right? i'll be waiting to hear your outcome and good luck on the install.
Old Feb 18, 2008 | 09:40 PM
<div class="FTQUOTE"><begin quote>Originally posted by: SPORTSMAN70003
I have a white bros. which is the same thing as the pure polaris exhaust and like it. You can add or remove disc for more power. Less disc the better bottom end will be and the more disc the better top end will be. Keep in mind the more disc you add the louder it will be. You might also need to add a bigger main jet depending on how rich your jetting is right now.</end quote></div>
would i have to buy a whole new jet kit?
Old Feb 18, 2008 | 10:19 PM
No since you done have the dyno jet kit. Look on the instructions and it will tell you what jet to use with an exhaust.
