Motor Won't Die!
I just finished putting a basket case back together. I got a 2001 325 Magnum that had been sitting up with a blown engine. I got it running and it runs pretty good except it won't stop running when I turn the key off! It will only stop when I use the red switch on the left handle grip. I have the manual and I've been through the wiring harness schematics and I can't find the answer. Any ideas before I replace the ignition switch?
mine did the same thing. when i posted the question most of the responses were to look for a disconnected ground wire. I never found one and it started working properly one day so i think it was a short in a ground wire somewhere. i guess besides looking for a disconnected wire look for any damaged or pinched wires also. Well at least its running
mrtidy
Feb 3, 2016 05:00 PM
