Blaster Swing Arm bearing removal and rebuild
Old Feb 19, 2008 | 11:35 AM
chuckneste's Avatar
Default Blaster Swing Arm bearing removal and rebuild
I have bought a tired Blaster. I have disassembled the chasis and I noticed not much of the rear swing arm but a sleeve inside that probably was a sub assy of something at one time. Any tricks or tips in removing any remains so a new swing arm kit can be installed? How are the bearings installed when new. Any hints or ticks
Thanks
Chuck
Old Feb 19, 2008 | 01:58 PM
qsportgoat's Avatar
i just did mine using a socket, (just undersized of the sleeves), extentions and a 3lb sledge.lots of wd40. the only thing that went wrong for me was the back of the extention got damaged from the sledgehammer.it took me about 15 mins. im sure they make a tool for it,but this woorked just fine for me. good luck
Old Feb 19, 2008 | 02:40 PM
chuckneste's Avatar
Thanks for the input. So did you remove or install the swing arm bearings this way. Sounds pretty simple. Mine is soaking is some wd 40. I capped the ends and filled it up with all soughts of good lubricants and sprays
Chuck
Old Feb 19, 2008 | 04:49 PM
Atvowner17's Avatar
Yea this theroy of the socket and mallot thing works great. can take a while tho.
Do if for removing and reinstalling.
Just be carefull not to ruin the bairings
Old Feb 19, 2008 | 06:04 PM
qsportgoat's Avatar
sorry, it was for both remove and install. i did use a piece of wood against the sleeve when starting them into the housing.
Old Feb 19, 2008 | 11:48 PM
Terrellster's Avatar
I just bought a good used SwingArm off ebay - 20 bucks. Problem solved.
Old Feb 20, 2008 | 03:41 PM
chuckneste's Avatar
Yup, The socket did the trick on one side. it's easier when you have one side missing a bearing. the other side has both bearings and will need to get one side out the hard way . I appreciate the feedback.
Ean
Dec 19, 2022 08:48 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
joeyupton
Jul 14, 2015 11:51 AM
